Beosound 1 Google assistant problem
Hiort
Sweden
Posts 2,895
Hiort Posted: Thu, Feb 21 2019 7:02 PM
Has anyone figured out how to activate and use the 4 shortcut “dots”?
Millemissen
Flensborg, Denmark
Posts 14,680
Have a look here - that may help
https://youtu.be/RUVj0c6rIcU
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Feb 22 2019 6:17 AM
Millemissen:
Thanks for the link.
My problem is that the four shortcut dots are not even lit up. Nothing happens when I press where I think they would be...
Millemissen
Flensborg, Denmark
Posts 14,680
Not knowing what you already have done, I’d say that it probably has something to do with how it is set up initially.
Has it been updated to the latest firmware?
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Feb 22 2019 11:40 AM
Millemissen:
Followed the setup flow provided when you first initiate the speaker.
That is done through the Google home app.
Will ask my dealer for advise.
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Feb 22 2019 1:35 PM
My dealer told me that this feature is yet to be rolled out in a coming release.
Sounds strange since e.g the Manchesterguys have it working on theirs.
My BS1 says its up to date....
christiank
Posts 64
Like it is mentioned in this video https://youtu.be/2-7hBZXn1Bw , right now the buttons will only show up if your primary language on the Google assistant is set to US or UK English.
You can still use it with (I'm guessing now) swedish, since you can select 2 languages - but US or UK English has to be the top one of those two.
Hiort
Sweden
Posts 2,895
Hiort replied on Fri, Feb 22 2019 6:49 PM
christiank:
I now did a factory reset and did a new installation with the iPad set to English.
Then the dots appeared.
So, the Google Home need to be English from start.
I tried to change after the installation (when app in Swedish was used) but that did not help.
A bit cumbersome for the average user, but hopefully the feature will come in Swedish language soon.
Page 1 of 1 (8 items) | RSS
