Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Have a look here - that may help
https://youtu.be/RUVj0c6rIcU
Millemissen:Have a look here - that may help https://youtu.be/RUVj0c6rIcU MM There is a tv - and there is a BV.
Not knowing what you already have done, I’d say that it probably has something to do with how it is set up initially.
Has it been updated to the latest firmware?
Millemissen:Not knowing what you already have done, I’d say that it probably has something to do with how it is set up initially. Has it been updated to the latest firmware? MM There is a tv - and there is a BV.
My dealer told me that this feature is yet to be rolled out in a coming release.
Sounds strange since e.g the Manchesterguys have it working on theirs.
My BS1 says its up to date....
Like it is mentioned in this video https://youtu.be/2-7hBZXn1Bw , right now the buttons will only show up if your primary language on the Google assistant is set to US or UK English.
You can still use it with (I'm guessing now) swedish, since you can select 2 languages - but US or UK English has to be the top one of those two.
christiank:Like it is mentioned in this video https://youtu.be/2-7hBZXn1Bw , right now the buttons will only show up if your primary language on the Google assistant is set to US or UK English. You can still use it with (I'm guessing now) swedish, since you can select 2 languages - but US or UK English has to be the top one of those two.
