Beosystem 4500 not working
This post has 4 Replies | 0 Followers
valve1
The south of France and occasionally Dublin Ireland
Posts 1,502
valve1 Posted: Thu, Apr 4 2019 10:53 AM
My beosystem which I have had a good few years has sometime recently decided not veto work.
The beomaster just stays turned on and will not respond to the remote control.
The cd and cassette player will manually turn on but they are not communicating with the speakers.
Seems there are a few issues, any thoughts ?
solderon29
U.K.West Midlands
Posts 764
Is there a standby light on the Beomaster?
Praps a silly question,but does the Beomaster respond to manual commands at the glass operation panel?
If so,do you need to reset the option code?(sound-1-store,via BL1000.Unit in standby)
Nick
valve1
Posts 1,502
valve1 replied on Thu, Apr 4 2019 5:04 PM
Hi Nick It's not responding to manual commands, it will not even turn off.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Apr 4 2019 10:14 PM
Check with a scope that the CPU in the Beomaster is running.
The other units will not cause anything else to react, if the Beomaster is down.
valve1
Posts 1,502
valve1 replied on Fri, Apr 5 2019 6:50 AM
As I have no scope I might just post it to you next week Martin ;-)
Eddie
Page 1 of 1 (5 items) | RSS
