Replacing trimmers?
This post has 8 Replies | 0 Followers
Agent00soul
Posts 15
Agent00soul Posted: Thu, Oct 18 2012 11:04 AM
When recapping 70's Beomasters, is it recommended to replace the trimmer potentiometers at the same time?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Oct 18 2012 12:57 PM
Depends on the type originally fitted, but in most cases yes.
Agent00soul
Posts 15
Dillen:
OK, are there recommended types for this, or should ordinary open carbon trimmers (like in original) be used?
Søren Mexico
Mexico City
Posts 6,411
I have been using Piher and Bourns, closed types,
chartz
Burgundy, France
Posts 4,171
chartz replied on Thu, Oct 18 2012 1:53 PM
Søren Mexico:
I have been using Piher and Bourns, closed types.
I agree, Pihers (cermet or carbon) are okay and cheap. There are better alternatives, but they are usually unnecessarily expensive.
I have always wondered why B&O didn't use encapsulated trimmers in the first place!
Replace them anyway, but if you can avoid touching the tuner ones, leave them well alone.
Jacques
Søren Mexico
Mexico City
Posts 6,411
Here for type
Dillen
Posts 13,191
Dillen replied on Thu, Oct 18 2012 3:53 PM
You can use the open carbon type like the original, that'll be fine.
However, the slightly better closed types are not much more expensive so consider those unless
you have the open type already in the drawer.
BTW, not all closed types are better. B&O actually used some closed types, particularly in the TV range
and I'm sure that many repairers will agree that those shiny/orange ones used in the LX25/28 series vertical circuit
are components from hell. I don't do a lot of TVs but I've still repalced a lot of them.
At least with the open types you can visually tell when they are falling apart.
Agent00soul
Posts 15
OK, I looked up the Piher closed cermet trimmers. These are available with 5 x 10 mm pinout at very decent prices. That looks to me like the best choice. In the drawer I only have cermets with 5 x 2.5 mm pinout, so I'll have to order these.
Søren Mexico
Mexico City
Posts 6,411
Agent00soul:
You can also order by Martin, also closed and good onesLaughing, and while you are at it why not the caps too. easier and fast delivery, just not to Mexico
Page 1 of 1 (9 items) | RSS
