Hello
Does anyone have the electronic diagram of the beolab 4000 speaker, to pass me?
Thank you. regards
Manu
I found it in products.
Does anyone know why the speakers are not activated and the LED does not appear in green and is always in red and the sound is not heard ???
Beomanu:Does anyone know why the speakers are not activated and the LED does not appear in green and is always in red and the sound is not heard ???
That will depend on the serial number.
If you have old Beolab 4000 with black foam inside, then that has almost certainly degraded to the point of damaging the main circuit board which will have caused the problem.
If you have white foam inside then it is a newer Beolab 4000 and the other issues to check is the standby transformer which is also a common failure.
Regards Keith....
Many thanks por your info
B regards
