Beolab 4000
Beomanu
Posts 5
Beomanu Posted: Mon, May 27 2019 3:49 PM
Hello
Does anyone have the electronic diagram of the beolab 4000 speaker, to pass me?
Thank you. regards
Manu
Beomanu
Posts 5
Beomanu replied on Mon, May 27 2019 4:15 PM
I found it in products.Smile
Beomanu
Posts 5
Beomanu replied on Mon, May 27 2019 4:17 PM
Does anyone know why the speakers are not activated and the LED does not appear in green and is always in red and the sound is not heard ???
beolion
Posts 485
beolion replied on Mon, May 27 2019 4:27 PM
Beomanu:
I had a similar problem caused by the foam that was deteriorated. It damaged the electronics.
I had it repaired and new foam placed.
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
That will depend on the serial number.
If you have old Beolab 4000 with black foam inside, then that has almost certainly degraded to the point of damaging the main circuit board which will have caused the problem.
If you have white foam inside then it is a newer Beolab 4000 and the other issues to check is the standby transformer which is also a common failure.
Regards Keith....
Beomanu
Posts 5
Beomanu replied on Tue, Jun 4 2019 10:55 AM
Many thanks por your info
B regards
Beomanu
Posts 5
B regards
Page 1 of 1 (7 items) | RSS
