Advice on connecting Beosound Moment to Beosound 9000
mmctsai
Posts 20
mmctsai Posted: Tue, Jun 18 2019 7:04 AM
Dear all,
Appreciate if anyone can advice ways on connecting Beosound Moment to my Beosound 9000 set up, pls see my current set up below,
Beosound 9000 with Y powerlink splitter for Beolab 5(Front) and Beolab 3(Rear)
Aux in with splitter for  1.TV/media box sound source (converter) and 2.Airport Express (wireless for ipad music source)
The current set up has been working great however I would like to have this new besound moment to replace ipad music source to music streaming. I couldn't figure out how to link moment to beosound 9000 with the current speakers, thanks in advance.
Mike
beojeff
USA
Posts 2,012
beojeff replied on Tue, Jun 18 2019 12:55 PM
The ideal solution would be to connect the BS9000 to an NL/ML Converter. Then, the Moment and the BS9000 can share their sources. You could connect the speakers to either the Moment or the BS9000. I have a BeoSound 9000 (without speakers) connected to an NL/ML Converter and it's great. I can play and control the BS9000 from any B&O device (NL or ML; audio or video) in my home.
beojeff
USA
Posts 2,012
beojeff replied on Tue, Jun 18 2019 1:07 PM
If using an NL/ML Converter with the speakers connected to the BS9000, you would have two options for how you use the B&O remote:
(1) If your BS9000 is N.Music and N.Radio compatible (i.e. MK3 or updated) then you could set the NL/ML converter role as "source center." Then you can assign the N.Music and N.Radio Beo4 commands to sources from the Moment.
(2) Otherwise, you could set the NL/ML converter role as video master. Then, you can map Moment sources to Beo4 video commands such as "TV," "DVD," etc.
mmctsai
Posts 20
mmctsai replied on Tue, Jun 18 2019 2:43 PM
Thanks for your prompt assistance, I’d like to figure out how to sound out / line out to Aux in?
mmctsai
Posts 20
mmctsai replied on Tue, Jun 18 2019 2:46 PM
From beosound moment can I sound out from speaker  port to Aux in? Thanks
mmctsai
Posts 20
mmctsai replied on Thu, Jun 20 2019 1:51 AM
Got it all working now, bought RJ45 - DIN Aux cable, plug in moment's speaker out port and aux in BS9000. Moment can stream music and wireless connect to iPhone/ipod music. Happy with the set up!
mmctsai
Posts 20
mmctsai replied on Thu, Jun 20 2019 1:52 AM
Trying to set up speakers linked with BS9000, anyone knows these options? Beovox 1, Beovox 2, Line?
mmctsai
Posts 20
mmctsai replied on Mon, Jun 24 2019 2:29 AM
Tried Beovox 1 or 2 option, the sound level became very low so I had to adjust with moment volume wheel to as high as 70% so I can hear any sound;
Tried Line option, the sound level seems normal but cannot adjust with moment wheel.
Does anyone know what Beovox and Line means and which option should I choose? many thanks.
Page 1 of 1 (8 items) | RSS
