Dear all,
Appreciate if anyone can advice ways on connecting Beosound Moment to my Beosound 9000 set up, pls see my current set up below,
Beosound 9000 with Y powerlink splitter for Beolab 5(Front) and Beolab 3(Rear)
Aux in with splitter for 1.TV/media box sound source (converter) and 2.Airport Express (wireless for ipad music source)
The current set up has been working great however I would like to have this new besound moment to replace ipad music source to music streaming. I couldn't figure out how to link moment to beosound 9000 with the current speakers, thanks in advance.
Mike
The ideal solution would be to connect the BS9000 to an NL/ML Converter. Then, the Moment and the BS9000 can share their sources. You could connect the speakers to either the Moment or the BS9000. I have a BeoSound 9000 (without speakers) connected to an NL/ML Converter and it's great. I can play and control the BS9000 from any B&O device (NL or ML; audio or video) in my home.
If using an NL/ML Converter with the speakers connected to the BS9000, you would have two options for how you use the B&O remote:
(1) If your BS9000 is N.Music and N.Radio compatible (i.e. MK3 or updated) then you could set the NL/ML converter role as "source center." Then you can assign the N.Music and N.Radio Beo4 commands to sources from the Moment.
(2) Otherwise, you could set the NL/ML converter role as video master. Then, you can map Moment sources to Beo4 video commands such as "TV," "DVD," etc.
Thanks for your prompt assistance, I’d like to figure out how to sound out / line out to Aux in?
From beosound moment can I sound out from speaker port to Aux in? Thanks
Got it all working now, bought RJ45 - DIN Aux cable, plug in moment's speaker out port and aux in BS9000. Moment can stream music and wireless connect to iPhone/ipod music. Happy with the set up!
Trying to set up speakers linked with BS9000, anyone knows these options? Beovox 1, Beovox 2, Line?
Tried Beovox 1 or 2 option, the sound level became very low so I had to adjust with moment volume wheel to as high as 70% so I can hear any sound;
Tried Line option, the sound level seems normal but cannot adjust with moment wheel.
Does anyone know what Beovox and Line means and which option should I choose? many thanks.
