I am thinking of buying a Beocentre 8500 to link with a pair of Beovox S75 speakers.
I’d also like to connect an Amazon Echo Dot to the Beocentre, so that I can also stream music through the amp and passive speakers.
Is this possible and if it is, how is it done i.e. what type of specific connection cable do I need to link the Echo to the B&O unit.
Many thanks to anyone who can help.
C
Hi and welcome to Beoworld!
You can easily connect the Echo Dot to the Beocenter's TV/AUX input, for which you should use one of these cables: https://soundsheavenly.com/bang-olufsen/67-298-minijack-to-aux-in-ipod-to-beosound-beomaster-beocenter-using-aux-din-socket.html#/2-length-1m
Amazing response!!
Thank you.
Will be in touch for sure as soon as I buy the Beocenter.
Do you also also have speaker leads from the Beocenter for the the S75s?
Kill two birds with one stone!
Many thanks.
Hi C,
Welcome to BeoWorld! Thanks for posting the link to my site Guy, you beat me to it. I also stock the speaker cables here:-
https://soundsheavenly.com/beovox-passive-unpowered-loudspeakers/24-1-2-pin-din-beovox-cx-speaker-cables-pair-also-for-beovox-2500-and-rondstraler.html#/5-length-5m
Please ask if you have any questions.
Kind regards Steve.
Steve.
www.soundsheavenly.com
