Echo Dot with Beocentre 8500
This post has 3 Replies | 2 Followers
Broociefan
Posts 4
Broociefan Posted: Sun, Jul 14 2019 8:57 AM
I am thinking of buying a Beocentre 8500 to link with a pair of Beovox S75 speakers.
I’d also like to connect an Amazon Echo Dot to the Beocentre, so that I can also stream music through the amp and passive speakers.
Is this possible and if it is, how is it done i.e. what type of specific connection cable do I need to link the Echo to the B&O unit.
Many thanks to anyone who can help.
C
Guy
Warwickshire
Posts 2,590
Guy replied on Sun, Jul 14 2019 10:18 AM
Hi and welcome to Beoworld!
You can easily connect the Echo Dot to the Beocenter's TV/AUX input, for which you should use one of these cables: https://soundsheavenly.com/bang-olufsen/67-298-minijack-to-aux-in-ipod-to-beosound-beomaster-beocenter-using-aux-din-socket.html#/2-length-1m
Broociefan
Posts 4
Broociefan replied on Sun, Jul 14 2019 12:46 PM
Amazing response!!
Thank you.
Will be in touch for sure as soon as I buy the Beocenter.
Do you also also have speaker leads from the Beocenter for the the S75s?
Kill two birds with one stone!
Many thanks.
C
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
 Hi C,
Welcome to BeoWorld!  Thanks for posting the link to my site Guy, you beat me to it.  I also stock the speaker cables here:-
https://soundsheavenly.com/beovox-passive-unpowered-loudspeakers/24-1-2-pin-din-beovox-cx-speaker-cables-pair-also-for-beovox-2500-and-rondstraler.html#/5-length-5m
Please ask if you have any questions.
Kind regards Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (4 items) | RSS
