Beocord 1101 on/off switch
bidstonhall
Thailand 5560 miles from Struer
Posts 363
bidstonhall Posted: Fri, Jul 19 2019 7:35 AM
Hi all, the on/off switch has failed on my cassette player, won't remain in the on position
does anybody know how to dismantle the front panel, there are lots of manuals available all over the web but these are service manuals and don't have instructions for dismantling in the first instance
any help would be much appreciated
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Jul 19 2019 12:09 PM
Top plate off (two screws at the back and a clip holding the VU-meters).
Side panels off (if plastic based just pry them off carefully, if metal based two grub screws each side under the top plate).
Now you should be able to see what's going on.
The upper and lower rails are held by these holders and locking wedges:
https://beoparts.com//?s=beocord+1100+front+rails&search=Go
Some power switches are fitted with screws tightened from the inside, others from the outside through the front rails.
Perhaps this will help:
https://archivedforum2.beoworld.org/forums/p/6736/255085.aspx
and this:
https://www.ebay.ie/itm/BANG-OLUFSEN-BEOCORD-1100-CASSETTE-DECK-PARTS-POWER-SWITCH/293024385765?hash=item44399d4ae5:g:lEkAAOSwYCRb2Fx7
bidstonhall
Posts 363
Fantastic, job done
Page 1 of 1 (3 items) | RSS
