Hi there, I have a beosound 1 supplied by Lee at Lifestyle and can confirm there is no pincode
I've had BS1's for reapir and can confirm that there are versions with pincode. This is an option whether it's set or not.
The original manual mentions nothing about a pincode, so you can assume that the first are without pincode.
When pincode is activated the "PIN" appears behind the alu grill.
Its such a long time ago but some products had pin code but it wasn't active when it left the factory. It was customer choice if they wished to use the security feature.
It was after this period that products with PIN were then active from the factory.
Opman
There where two variants of the beautiful Beosound 1:- Beosound 1 MK1: no Pincode- Beosound 1 MK2: Pincode
