Besound 1 (old) without pincode
This post has 5 Replies | 0 Followers
Ferdinand
Malmö, Sweden
Posts 541
Ferdinand Posted: Thu, Aug 29 2019 10:09 AM
Hello all,
I am in need of some advice,
I am looking for a 2nd hand BS1 (old) CD/Radio player.
Not all of them come with the pincode and one seller actually informed me that older models didn’t have one?
Any confirmation on that?
bidstonhall
Thailand 5560 miles from Struer
Posts 363
Hi there, I have a beosound 1 supplied by Lee at Lifestyle and can confirm there is no pincode
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Thu, Aug 29 2019 3:02 PM
I've had BS1's for reapir and can confirm that there are versions with pincode. This is an option whether it's set or not.
The original manual mentions nothing about a pincode, so you can assume that the first are without pincode.
When pincode is activated the "PIN" appears behind the alu grill.
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Thu, Aug 29 2019 10:27 PM
Its such a long time ago but some products had pin code but it wasn't active when it left the factory. It was customer choice if they wished to use the security feature.
It was after this period that products with PIN were then active from the factory.
Opman
TWG
Posts 1,672
TWG replied on Fri, Aug 30 2019 5:23 AM
There where two variants of the beautiful Beosound 1:
- Beosound 1 MK1: no Pincode
- Beosound 1 MK2: Pincode
Ferdinand
Malmö, Sweden
Posts 541
Ferdinand replied on Fri, Aug 30 2019 8:03 PM
Well, i picked up the unit today. Radio, CD worked, Display worked all buttons worked and so did the antenna.
Just showed it at home briefly and was still working. Will know more next week when I will have it at work where I will use it as radio primarly. It came with BT dongle as well so I can stream to the unit as well.
It came with a faulty Beo4 where the off (red) button doesnt work - any tips on how to go about here?
Page 1 of 1 (6 items) | RSS
