Use speakers connected to BeoVision Avant for Beosound 3200 playback
This post has 9 Replies | 2 Followers
cge01
Paris
Posts 21
cge01 Posted: Sat, Sep 7 2019 7:14 PM
Hello,
I am a bit new in the B&O World, and I have a question that will probably look a bit silly for most of you. However I searched for the answer in the manuals and in the forum, and I still cannot figure it out.
I have a Beovision Avant 55 with 4 speakers connected (Powerlink). I would like to use these speakers to play some CD's as well. Therefore I am looking at a way of connecting a Beosound 3200 to the TV.
Is it possible? If yes, are there any restrictions? If not, is there is a workaround?
Thank your for help
Christian
Living room Avant 55 MK1 - BL5 x2 - BL6000 x2 - BS3200 - Core - NL/ML Converter - Thorens turntable
Bedroom BV7-40 MK6 - BL4 x2 - BL8000 x2 - BL11 - MLGW - Lutron GFX - RaspberryPi Domoticz
Bathroom BL2000 on BLC1611 with Chromecast audio
Kitchen Core - BL3 x2
Garden Core - Beolink Passive on 2x Bose Freespace 51
ed7
Posts 106
ed7 replied on Sun, Sep 8 2019 3:43 PM
Hi Christian  welcome to beoworld ,the short answer is yes you can , check this arrangements  on bv7-32  (reference book) page 50, I would imagine bs3200 was too old to include in  bv avant/Ng configurations?!
Hope that helps
https://www.bang-olufsen.com/en/product-support
kuyttendaele
Posts 707
You could connect the Aux of the 3200 to the Aux in of the Avant but that’s not the most elegant solution.
In an ideal situation you would need an MasterLink to Netlink convertor in order to connect the MasterLink for the 3200 and convert it into the current NetLink of the Avant.
cge01
Paris
Posts 21
cge01 replied on Sun, Sep 8 2019 6:37 PM
Thanks for your answer. I will use a convertor.
Regards
Aussie Michael
Melbourne, AU
Posts 3,730
I have also played CDs by playing in the slot loading CD DVD player. It is a Toshiba one I have mounted at the rear top if the Avant. It’s quite neat.
But I appreciate you want to use your BeoSound. And yes you would need an ML to NL converter.
If you’re in Australia I saw one for sale on eBay through DanishAV recently
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Use 1 free analog socket of the BV11 and name it "CD" . Option 2 for the BV11. Connect the BS3200 with this analog socket and set it in option 1. After a command of CD on the remote, the BV11 will switch on and the BS3220 will also startup and respond to your instructions on your remote.
Millemissen
Flensborg, Denmark
Posts 14,680
.....and the volume control - where does that go?
cge01
Paris
Posts 21
cge01 replied on Mon, Sep 9 2019 1:09 PM
Thanks. Unfortunately I am as far as I can be from Australia.
I'll find one on eBay here in Europe
Beobuddy
Posts 3,972
The BV11 responds to the CD instruction if it's set in option 2. So, volume should then also be controlled. Just connect the AUX from the BS3200 to the BV11 analog inputs. Should work.  A friend has the same setup with a BC2.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi cge01,
Welcome to Beoworld!
Yes, for either version of Avant 55, you can link the Beosound into the audio input of the TV to share the speakers:-
Avant mk.1 (9 pin AV socket): https://soundsheavenly.com/tv-input/138-2294-9-pin-av-cable-for-beovision-11-12-new-generation-avant-v1-and-beosystem-4-powerlink-input.html#/4-length-3m
Avant mk.2 (3.5mm L/R In socket): https://soundsheavenly.com/televisions/158-2365-powerlink-to-beovision-14-horizon-cable-link-your-audio-system-to-your-new-tv.html#/2-length-1m
Please turn up the volume of the Beosound to give normal control from the TV remote.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (10 items) | RSS
