Hello,
I am a bit new in the B&O World, and I have a question that will probably look a bit silly for most of you. However I searched for the answer in the manuals and in the forum, and I still cannot figure it out.
I have a Beovision Avant 55 with 4 speakers connected (Powerlink). I would like to use these speakers to play some CD's as well. Therefore I am looking at a way of connecting a Beosound 3200 to the TV.
Is it possible? If yes, are there any restrictions? If not, is there is a workaround?
Thank your for help
Christian
Living room Avant 55 MK1 - BL5 x2 - BL6000 x2 - BS3200 - Core - NL/ML Converter - Thorens turntable Bedroom BV7-40 MK6 - BL4 x2 - BL8000 x2 - BL11 - MLGW - Lutron GFX - RaspberryPi DomoticzBathroom BL2000 on BLC1611 with Chromecast audioKitchen Core - BL3 x2Garden Core - Beolink Passive on 2x Bose Freespace 51
Hi Christian welcome to beoworld ,the short answer is yes you can , check this arrangements on bv7-32 (reference book) page 50, I would imagine bs3200 was too old to include in bv avant/Ng configurations?!
Hope that helps
https://www.bang-olufsen.com/en/product-support
Thanks for your answer. I will use a convertor.
Regards
Use 1 free analog socket of the BV11 and name it "CD" . Option 2 for the BV11. Connect the BS3200 with this analog socket and set it in option 1. After a command of CD on the remote, the BV11 will switch on and the BS3220 will also startup and respond to your instructions on your remote.
.....and the volume control - where does that go?
Thanks. Unfortunately I am as far as I can be from Australia.
I'll find one on eBay here in Europe
The BV11 responds to the CD instruction if it's set in option 2. So, volume should then also be controlled. Just connect the AUX from the BS3200 to the BV11 analog inputs. Should work. A friend has the same setup with a BC2.
Hi cge01,
Welcome to Beoworld!
Yes, for either version of Avant 55, you can link the Beosound into the audio input of the TV to share the speakers:-
Avant mk.1 (9 pin AV socket): https://soundsheavenly.com/tv-input/138-2294-9-pin-av-cable-for-beovision-11-12-new-generation-avant-v1-and-beosystem-4-powerlink-input.html#/4-length-3m
Avant mk.2 (3.5mm L/R In socket): https://soundsheavenly.com/televisions/158-2365-powerlink-to-beovision-14-horizon-cable-link-your-audio-system-to-your-new-tv.html#/2-length-1m
Please turn up the volume of the Beosound to give normal control from the TV remote.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
