Recently when I turn on Sky Q, I get the ATV HDMI2 icon at the top of the screen. Don’t get me wrong, I am tuned into SkyQ , it’s just the wrong icon at the top of the screen. So not desperately worried, just annoying. This is a recent phenomenon. Can it be corrected?
thorne:Recently when I turn on Sky Q, I get the ATV HDMI2 icon at the top of the screen. Don’t get me wrong, I am tuned into SkyQ , it’s just the wrong icon at the top of the screen. So not desperately worried, just annoying. This is a recent phenomenon. Can it be corrected?Thanks
Best regards - Dyssegaard
Living room: Beovision Eclipse 55, Beolab 3 / R1 (back), Beolab 2 / R1 (sub), AppleTV 4K. Bedroom: Beovision 11-40, AppleTV 4. Home office: Beoplay M5. Kitchen: Beoplay M5. Travel: Beoplay H8, Beoplay A1. NAS: WD My Cloud Home / Plex DLNA Server.
thorne:Recently when I turn on Sky Q, I get the ATV HDMI2 icon at the top of the screen. Don’t get me wrong, I am tuned into SkyQ , it’s just the wrong icon at the top of the screen. So not desperately worried, just annoying. This is a recent phenomenon. Can it be corrected? Thanks
BeoVision Haermony 65"...BeoLab 28 Anthracite....BeoLab 17 as REAR....BV10-32....BC6-26....Beosound 9000....Beosound 1 New York edt....Beogram 4002....Beoplay Emerge....Beoplay M5....Beoplay M3....Beoremote Halo....BeoRemote One BT....Beo6....Beo4....Beo4 Cinema....BeoLink 7000....Serene....H95 Black LTD....H9i Rimowa....6 x H6....Form 1....U70...
Hi thanks for useful reply. I get the ATV line even when I tune into sky q, turn off, then tune into sky q again. But I guess it’s much the same problem. We’ll wait for the update
Fingers crossed, but I seem to have solved the issue by simply switching off the Eclipse at the mains for a few minutes, then switching back on
Spoke too soon. I’ll wait for update!
Would appreciate a nudge when the update happens and all is well
thanks
Any news on this issue?
I am still experiencing the same problem
thorne:Any news on this issue? I am still experiencing the same problem
I saw this in another forum about LG Oled tvs, (I don't know if this relates to your issue but it's worth taking a look and playing around):
Go to settings with a long press of the gear icon- connections- device connections- choose your device- choose HDMI port- press right on device reset - press next, and next again- choose the brand in the search field, press next en do the configuration.
I translated this from Dutch to English and I don't own the eclipse yet so not sure if I choose the correct words, but let me know if it helps.
Another tip, In order to hard-reboot the WebOS:
Go to General, About this TV, User Agreement. Change the agreements to outside EER off. The TV tells you that the license have been changed and needs to reboot. Now this will hard reboot the TV, withouth having to unplug the power.
- Beovision Eclipse 55 Mk2 - Beolab 19 - Beosound Shape - Oppo UDP-203
Same here!
I have a 2nd edition Eclipse (G1 screen) and have also the same problem with wrong name on the source when switching between HDMI sources from standby.
/Martin
NEW! Beovision Eclipse 65 2nd generation (G1) with floorstand (from STB Brackets), Beolab 50 front, Beolab 3 rear, 2 x Beoplay A6 linkrooms, 2xBeoremote one BT, Beosound 9000 Mark III (sw 3.4), Beosound 5 (for DLNA only), Philips Hue (all lights in the home), Oppo UDP-203, Apple TV 4K (2021 model). Beoremote HALO, 3xBeoplay Charging pad, Beoplay M5
Got my eclipse yesterday and I'm having the same issue. Haven't really fiddled around with it yet, anyone found a solution? Everything works OK, but it just shows the wrong input name.
Still no solution from me. I contacted B&O support who have escalated the issue, so we’ll wait and see!
I received the following reply from B&O support
thorne:I received the following reply from B&O support Our management has reviewed your case and has advised that soundcenter is "telling" the screen to display this info, but the TV ignores this message and will display the previously used source. This is issue has been reported to LG some time ago by our product development team but we are currently still waiting on a resolution from LG.
Hi
you make a good point. Buck passing?
