US to UK voltage conversion...
davidosborne436
Posts 37
davidosborne436 Posted: Tue, Oct 8 2019 10:56 PM
A question I thought I knew the answer to but I'd like to check. If I take a Beogram 5005 from the US to the UK and use a voltage converter isn't the speed a problem (because of the 50-60Hz difference) or does the Beogram compensate for this difference?
Thx
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Wed, Oct 9 2019 6:23 AM
Beogram 5005 uses a DC-servo motor. All electronically controlled.
Works fine on both 50Hz and 60Hz mains.
davidosborne436
Posts 37
Thanks. Appreciate it. Makes my life easier.
Page 1 of 1 (3 items) | RSS
