A question I thought I knew the answer to but I'd like to check. If I take a Beogram 5005 from the US to the UK and use a voltage converter isn't the speed a problem (because of the 50-60Hz difference) or does the Beogram compensate for this difference?
Thx
Beogram 5005 uses a DC-servo motor. All electronically controlled.Works fine on both 50Hz and 60Hz mains.
Thanks. Appreciate it. Makes my life easier.
