Hey
Just got a Beosound 4 from 2007.
The soft plastic is sticky .
I have asked some that say it can not be "cleaned" but need new paint , but just want to ask here also.
Have anyyone tried to repair the plastic on BS 4 ?
Anders
You can wipe it all clean of dust and dirt and spray it with satin black (or matt black) automotive paint - but it's nothing like original. It will just seal in the sticky and create a new, non-sticky surface.
I recommend this :
https://www.ebay.co.uk/itm/400ml-Autosmart-MATT-Black-spray-400ml/333275848023?hash=item4d98c9dd57:g:~V4AAOSw3utY8KRy
Lee
Hi Lee
Ok thank you.
But will I not also be spraying into the eletronic ? Top and button there I se einto the eletronic
br
anders
Here's someone's fix that I've heard about previously. 'Haven't tried it so I can't comment on its effectiveness. If you try it, pls let us know if it worked (I have a BS 4 with the same problem).
anders92240: But will I not also be spraying into the eletronic ? Top and button there I see into the electronic
Apologies - I assumed you'd be stripping it down to do any refurb work...
In which case, I have no suggestions apart from a new casing fitted by an approved B&O Service Center.
Other methods may work, but I've never found any (not to say there aren't any!_
Those "soft-touch" surfaces are one of the worst inventions in recent time -like using "foam-rings" in speaker units instead of rubber... But the decomposition of the surface seems to be dependent on the environment in which it has been stored (humidity etc.).
I have bought two (secondhand) Beocenter 2 systems. On one of them, the socket-box was fine -on the other it was sticky.
I spray painted the surfaces with matte black paint. But offcourse you'll have to take it apart - or cover the parts that shall not be painted, with plastic/tape.
hi
as thay suggest..it's best if you stip it total...so you have only plastic parts..
1. only clean with iysopropanol .
2..spray first with car paint prymer 5x ..sandpaper it to nice to a beautiful flat finish.
3.spray black matt paint. ..do it from 50cm ,,,5x thin. so you get nice finished surface :)
i do that with BS4 or BL3 or Beosound 2 socket unit
Hi all
Thank you very much.
I have been offered a New orginal B&O rear cover / chassis for 73 euro.
I dont know, I can also try to paint as you all describes. Instead of normal mat black what about 'rubber plastic spray' ? plasti dip https://www.caradisiac.com/Plasti-Dip-un-produit-vraiment-bluffant-videos-76696.htm
Thinks that it will maybe get a bit of the orginal feeling without getting sticky ?
anders92240:Hi all Thank you very much. I have been offered a New orginal B&O rear cover / chassis for 73 euro.
Hi again
Just wanted to ask how diffucult you would say it is to take the BS 4 appart so I can clean and paint the rearcover and the frontcover ?
1 to 5 where 5 is very diffucult ? ( for someone that usually dont do somethink like this )
I did found the PDF for BS 4 service manual that show how to take it appart
It's 2-3 out of 5.
