Motorized floor stand and table stands for BV 7-40 and 7-55
This post has 3 Replies | 0 Followers
Peter
Sweden
Posts 84
Peter Posted: Tue, Nov 5 2019 10:04 AM
HI all,
I currently have a Beovision 7-40 with the original motorised floor stand, and I am now about to buy a second hand 7-55 with a motorised table stand and also an optional wall bracket.
My question is, can a 7-55 use the same floor stand i am using for my 7-40?
Are the various stands and wall brackets compatible between a 7-40 and a 7-55?
Thanks in advance
/Peter
Beovision 7-40 Mk VI, Beovision 3-32, Beovision AV9000, Beovision AV5, Beolab 8000, 6000, 5000, 3000, 2000,  Beocenter 2300, 9000, Beocenter 2, DVD1, DVD2, Beogram 3300, LC2, Beolit 12, 3 x AppleTV
Rob - Danish AV
Melbourne
Posts 376
Hi Peter,
They are not compatible sorry.
Peter
Sweden
Posts 84
Peter replied on Wed, Nov 6 2019 3:18 PM
Thanks for you quick reply Rob.
Too bad they aren't... :(
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Wed, Nov 6 2019 8:39 PM
If you keep the stands but want to upgrade the screens, STB brackets now make a converter plate that allows you to use any set with VESA mount. You could for example fit and LG screen with a Beosound Stage for an alternative to the Eclipse.
Regards
Opman
Page 1 of 1 (4 items) | RSS
