HI all,
I currently have a Beovision 7-40 with the original motorised floor stand, and I am now about to buy a second hand 7-55 with a motorised table stand and also an optional wall bracket.
My question is, can a 7-55 use the same floor stand i am using for my 7-40?
Are the various stands and wall brackets compatible between a 7-40 and a 7-55?
Thanks in advance
/Peter
---------------------------------------------------------------------------------------------------------------------------------Beovision 7-40 Mk VI, Beovision 3-32, Beovision AV9000, Beovision AV5, Beolab 8000, 6000, 5000, 3000, 2000, Beocenter 2300, 9000, Beocenter 2, DVD1, DVD2, Beogram 3300, LC2, Beolit 12, 3 x AppleTV
Hi Peter,
They are not compatible sorry.
Thanks for you quick reply Rob.
Too bad they aren't... :(
If you keep the stands but want to upgrade the screens, STB brackets now make a converter plate that allows you to use any set with VESA mount. You could for example fit and LG screen with a Beosound Stage for an alternative to the Eclipse.
Regards
Opman
