Beolab 4...static/crackling
bramble
Posts 397
bramble Posted: Fri, Nov 8 2019 12:13 PM
Hello,
As heading states......only from this one speaker!! Have changed pwr link cables and power cable still same issue......any ideas or do I bin it and buy replacement
Rgds
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 ๐Ÿ˜€๐Ÿ˜€
jvezina
Montreal, Canada
Posts 200
jvezina replied on Fri, Nov 8 2019 10:23 PM
Good evenind,
That looks like a failing amplifier board on the speaker.
See https://archivedforum2.beoworld.org/forums/t/37951.aspx
The solution is either to find and replace the defective MOSFET transistor (a DIY repair)  or to replace the board. B&O still has them in stock.
Regards,
Jean
marexy
Posts 710
marexy replied on Sat, Nov 9 2019 6:08 PM
If you only chage only MOSFET you did not repair it or maybe yes in 10% ..for short time.
A faulty MOSFET is just the result of some  XY error on the amplifier pcb.
Strange sound can also be caused by a malfunction on the other PCB of the speaker.
bramble
Posts 397
bramble replied on Sun, Nov 10 2019 11:14 PM
Thanks for your advice[:\'(]
bramble
Posts 397
bramble replied on Mon, Nov 11 2019 11:53 AM
Morning all,
The static/ crackling is coming from the tweeter , I have disconnected it and crackling stops.....is this still a fault with the board or just a replacement tweeter required...your thoughts would be appreciated
marexy
Posts 710
marexy replied on Mon, Nov 11 2019 12:20 PM
Tweeter is OK.
Problem is on power amp. PCB or crosower PCB.
Where are you from ?
bramble
Posts 397
bramble replied on Mon, Nov 11 2019 12:31 PM
Marexy hi, I live in Edinburgh...
marexy
Posts 710
marexy replied on Mon, Nov 11 2019 1:35 PM
You can repair it or buy new power amp board.
Page 1 of 1 (8 items) | RSS
DigiCert Secured Site Seal
