Configuration of NL/ML converter with Beovision Eclipse
RasmusB
Posts 3
RasmusB Posted: Wed, Dec 18 2019 10:14 AM
Hi All, I have the following setup:
  • Bevision Eclipse 65”
  • Beosound 5
  • Beolab 5 (directly attached to Beosound 5)
  • Beolab 8002 controlled by Beolink active
  • Beolab 3 controlled by Beolink active
  • Beolab 3500
  • MLGW
I recently purchased the Beovision Eclipse 65” (before I had Beovision 7) To connect all my products I also purchased the NL/ML converter (second hand). I have used a lot time to configure the NL/ML converter, however I have still not succeeded in having the sound from the Beovision Eclipse coming out of the other speakers in my setup. The converter is setup in V-master mode. I tried changing options on the Beosound 5. Im able to turn on any other speaker, connected to a TV source, however no sound is coming.
What am I missing here?
1990
Posts 521
1990 replied on Wed, Dec 18 2019 11:03 AM
Eclipse cannot send the TV sound to Masterlink. Only the other way round.
1990
Posts 521
See the Bang Olufsen Multiroom-handout.
Fansastic
The Hague, The Netherlands
Posts 768
Fansastic replied on Wed, Dec 18 2019 7:57 PM
I can send music from my Eclipse to my NL/ML converter and linked BS3000 to play the music. Also can play music from my BS3000 to the Eclipse.
NL/ML Converter:
RasmusB
Posts 3
RasmusB replied on Thu, Dec 19 2019 8:58 AM
What about the TV sound ? Can you send that to your NL/ML and distribute it on your other speakers?
Thanks for all your help,
Fansastic
Posts 768
Fansastic replied on Thu, Dec 19 2019 1:46 PM
RasmusB:
I need to check but as I recall the sound of tv was another source I could select in the setup menu for the NL/ML.
Will reply on this later
Fansastic
Posts 768
Fansastic replied on Thu, Dec 19 2019 8:12 PM
Fansastic:
I checked and can select Live Tv as source and play sound from the TV show to my NL/ML and connected BS3000. I selected the TV source as shown in the picture. Note I can only play 2 sources to my BS3000, not sure if I’m missing something but never found out how to add more sources. So I selected one source with the Eclipse Live TV (or any other source I can select in the drop down menu) and it works.
Hope this helps
RasmusB
Posts 3
RasmusB replied on Sat, Dec 21 2019 7:39 PM
I can select Live TV, Youtube, etc. I made the same setup as you have, even trying selecting one source only ( live TV)  the converter allows me to turn on the beolab 5's which are connected directly to my Beosund 5 -However no sounds is coming !!
Im confused, and start to think that something setup wise on Beosound 5 needs to be done, since you can have  TV sound from your Eclipse distributed through a NL/ML Converter ?
Could you send me the screen shoots of your complete configuration, to be sure the converter is configured right ?
Fansastic
Posts 768
Fansastic replied on Sun, Dec 22 2019 8:53 AM
In my earlier post I added picture of main setup page and the ML sources. I’m not experienced with ML but I can only select two sources on my BS3000 which play content. Maybe you can try different sources on the BS5 and fiddle a bit with the IR mapping.
If you want to check the converter first, you can connect speakers directly to the converter, I believe you need a IR controller also, so maybe not that easy.
Page 1 of 1 (9 items) | RSS
