Hi All, I have the following setup:
Bevision Eclipse 65”
Beosound 5
Beolab 5 (directly attached to Beosound 5)
Beolab 8002 controlled by Beolink active
Beolab 3 controlled by Beolink active
Beolab 3500
MLGW
I recently purchased the Beovision Eclipse 65” (before I had Beovision 7) To connect all my products I also purchased the NL/ML converter (second hand). I have used a lot time to configure the NL/ML converter, however I have still not succeeded in having the sound from the Beovision Eclipse coming out of the other speakers in my setup. The converter is setup in V-master mode. I tried changing options on the Beosound 5. Im able to turn on any other speaker, connected to a TV source, however no sound is coming.
What am I missing here?
Eclipse cannot send the TV sound to Masterlink. Only the other way round.
See the Bang Olufsen Multiroom-handout.
What about the TV sound ? Can you send that to your NL/ML and distribute it on your other speakers?
Thanks for all your help,
RasmusB:What about the TV sound ? Can you send that to your NL/ML and distribute it on your other speakers? Thanks for all your help,
Fansastic:I need to check but as I recall the sound of tv was another source I could select in the setup menu for the NL/ML. Will reply on this later
I can select Live TV, Youtube, etc. I made the same setup as you have, even trying selecting one source only ( live TV) the converter allows me to turn on the beolab 5's which are connected directly to my Beosund 5 -However no sounds is coming !!
Im confused, and start to think that something setup wise on Beosound 5 needs to be done, since you can have TV sound from your Eclipse distributed through a NL/ML Converter ?
Could you send me the screen shoots of your complete configuration, to be sure the converter is configured right ?
