Ny Beosound Core will not turn on and off my beokink Passive. They connected with a special Powerlink cable. This were pin 1 og 4 are solved.
The issue is not on the Beolink Passive since on and off is working fine if a replace Beolink Core with a Beolink Essence MK II.
If a disconnect the Powerlink cable the Beolink Passive turn off and when the cable is reconnected it turns on
This might tell me that there is power (5v) on pin 1 or pin 4 (do not recall which it is) all the time even when Beosound Core is put to Stand-by.
What is the issue?
Thanks a lot, but B&o Hellerup says that it is not correct and the mentioned cable must work.
Dealers have been known to be wrong at times. It certainly sounds like Peter may have actual experience solving this problem. If it were me, I'd give Peter's suggestion a try. You can always put the wire back if you prefer the current behavior.
Thanks. I wonder why B&O do not provide a cable that works.
Beoworld app with direct photo upload and emoticons.
