I am thinking about putting the Beosound 1 in the bathroom - quite high up. Which remote will work with the BS1 - I know the Beo5/6 will and the Beo4 but wanted something specific and cheaper for the bathroom.
Would any older remotes work?
Thanks.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
Rolf:A replacement remote from König
Have one, better forget it - range is much less and the buttons are not as logical as the BL1000.
And BL1000's are cheap meanwhile - between 20 and 30 EURs. (The König was some 12 EURs as I remember).
Definitely prefering the original.
I'm using the König near the bathtub - it it fell in no much damage done (and on bathing once a year the chance is low )
Gunther
