Beogram 8000 speed dips randomly
eggsovereasy
Posts 3
eggsovereasy Posted: Sat, Nov 3 2012 10:39 PM
I inherited a B&O system consisting of a Beogram 8000, Beomaster 8000, and a pair RL-60 speakers. When I got it the Beogram spun at an insanely high speed so after a little googling it was recommended I check the tachodisc. It was shot so I ordered a new one from some guy on the internet and installed it without issue (getting the suspension clips on and off is a pain though).
Now everything seems to be working well except that randomly the speed dips. It doesn't happen on every revolution or at any particular part of a given record. Sometimes it does it a couple times in rapid succession and sometimes I can make it through an entire song without it happening.
Any idea what could be the cause of this?
Once this issue is resolved I just have to find a suitable material to replace on the ABRs in the RL-60s and it will be all good to go Big Smile
Thanks!
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Nov 4 2012 9:40 AM
Grab a capacitor kit and replace the lot.
eggsovereasy
Posts 3
I ordered it from... you I think.
Thanks!
Page 1 of 1 (3 items) | RSS
