It would probably help us you tell us more about what the XBox is connected to, how it is connected, what remote you are using and if it has ever worked for you before. If it did work before, what have you changed?
Stoobie
If you have reset the Avant, you probably also have reset the PUC - means it is not assigned to the device/the HDMI input anymore.
It should be faitly easy to go into the settings to see, what has happened.
In case it is gone, you will have to assign (maybe download) it again.
Inferno82: i don’t know how it is relevant 🤔
I am sure you did not mean to come across as rude, but if you are having issues and want help, everything can be relevant. I see from the answer, that it seems it could be relevant in your case.
More detail is always better than less. Hopefully you can get it sorted.
