Puc
This post has 7 Replies | 2 Followers
Inferno82
Posts 47
Inferno82 Posted: Mon, Mar 16 2020 6:24 PM
Does anyone know what is wrong when xbox one s puc does not work?
Inferno82
Posts 47
Inferno82 replied on Wed, Mar 18 2020 5:00 PM
Is my question wrong?
Stoobietoo
Exeter, Devon, UK
Posts 692
It would probably help us you tell us more about what the XBox is connected to, how it is connected, what remote you are using and if it has ever worked for you before. If it did work before, what have you changed?
Stoobie
Inferno82
Posts 47
Inferno82 replied on Thu, Mar 19 2020 5:19 AM
I reset the avant ng, xbox one s worked before with beoremote one. It’s connected with hdmi cable but i don’t know how it is relevant 🤔
Millemissen
Flensborg, Denmark
Posts 14,680
If you have reset the Avant, you probably also have reset the PUC - means it is not assigned to the device/the HDMI input anymore.
It should be faitly easy to go into the settings to see, what has happened.
In case it is gone, you will have to assign (maybe download) it again.
Stoobietoo
Exeter, Devon, UK
Posts 692
Inferno82:
I am sure you did not mean to come across as rude, but if you are having issues and want help, everything can be relevant.  I see from the answer, that it seems it could be relevant in your case.
More detail is always better than less. Hopefully you can get it sorted.
Inferno82
Posts 47
Inferno82 replied on Thu, Mar 19 2020 10:06 AM
No not rude, i apolize, also my bad english
Inferno82
Posts 47
Inferno82 replied on Thu, Mar 19 2020 11:24 AM
I reset the avant, then i put the xbox back, and the tv told there is a new thing in hdmi 3 or 4 or something, then it told to asign puc, then i selected xbox one s. But beoremote doesn’t control it
Page 1 of 1 (8 items) | RSS
