What can you do with a MK I Beovision 9 with a screen that no longer turns on?
i understand your can’t repair it anymore.
it’s a mammoth TV to discard!
any ideas of what can be done to it? put a new screen inside it? Repurpose it??
I have a perfect bv50 screen you can have for a very low price Private message me
So it’s easy to fit the BV4-50 screen into the BV9?
It isn't that easy as suggested. Sorry.
Juist replacing the panel, yes. No problem. When it comes to placing a camera from a more recent BV4 into the BV9, mk1. Then no. You need a new frame with the special milled space for the camera. You must be very handy to mill that space into the frame from the BV9.
The cables have a different length, which need to be adapted as the BV9 and BV4 differ in length and type of cables. The infrared from the BV9 enters first a different board before it passes through to the BS3.
I've done this for a customer who insisted on having his BV9 mk2 repaired and converted to a mk4 with camera.
So, basically, changing the panel itself is rather easy and possible. Building the extra camera inside the frame will cost a lot more time and/or money. Frames are probably not available anymore by now.
If you replace the panel from one to another. Don't forget the transfer the specific parameters from new panel. These are not automatically measured by the camera.
Is there the possibility of using a non B&O panel? Like a LCD that will fit inside?
does the beosystem 3 at the back come apart so you can use it for other purpose?
