Hi
Should this be toggled to on or off on the Eclipse and Sky Q box?
I dont have an Eclipse, but if you're Q box is connected to the sound centre part of the TV, I'm not sure if it can handle HDMO CEC.
The TV may have the setting, but that assumes / works if the Q box is connected directly to the LG panel part.
Just a hunch mind.
thorne: Hi Should this be toggled to on or off on the Eclipse and Sky Q box?
thorne:Hi Should this be toggled to on or off on the Eclipse and Sky Q box?
Thanks. That’s what I thought
