Beolab 2 refurbished : polished :)
This post has 12 Replies | 0 Followers
Bzguy
Posts 18
Bzguy Posted: Mon, Feb 17 2020 4:14 PM
Hi all,
I only recently (finally !) acquired some B&O equipment, of which one is a Beolab 2 with some “battle scars”.
I found a service manual, so dismantling should not be any issue, and the idea is to refurbish the housing.
Questions are :
- is it “blasphemy” to paint the housing ? Since the current damage cannot just be cleaned off.
- does anyone have any experience doing so ? Tips and/or tricks ?
- if painting (spraying) is accepted, what colors in your opinion would look interesting ?
Jaffrey2230
Washington DC
Posts 520
I believe B&O themselves had painted some in red and other colors. If anything, I think a good paint job (spray paint) would improve the look over the standard grey industrial look. Go for it.
B&O in my life 😊:
  • Beolab 8002 + Beolab 2 + Beosound Core with Essence Remote (Office)
  • Beolab 6000 + Beolab 11 + Beosound Core with Essence Remote (Bedroom)
  • Beoplay A9 Mk2 (Living Room)
  • Beosound 1 with wireless dock (Portable)
  • Beosound Balance (Dining)
  • Beoplay H95 (Focused listening, travel)
  • Beoplay H9 (3rd gen) (retired)
  • Beoplay P6 (Portable)
  • Beotime wall clock (hallway entrance)
  • BMW X5 50i with B&O Audio Package (Commute/drive)
Beozip
Posts 368
Beozip replied on Mon, Feb 17 2020 6:04 PM
look here as an example ....
https://archivedforum2.beoworld.org/forums/t/17911.aspx
https://archivedforum2.beoworld.org/forums/t/3691.aspx
https://archivedarchivedforum2.beoworld.org/forums/t/3736.aspx
https://sound-affair.com/beolab-2-ferrari-red-carbon-fiber
https://www.gumtree.com/p/speakers/bang-olufsen-beolab-2-/1320539619
Smile
Bzguy
Posts 18
Bzguy replied on Mon, Feb 17 2020 6:30 PM
Thank you for your replies, I had a look : they all look pretty, one more special than the other one ;)
I cam across a painted one in “chrome”, like polished (resembles the BL8000 shiny housing), looked nice too ! Imagine the elbow grease that would go into polishing ... ;)
Is the housing cast aluminium ? Is there standard a coating or paint layer on it ? Looks like bare metal, but I can be wrong of course ...
Beozip
Posts 368
Beozip replied on Tue, Feb 18 2020 8:05 AM
here you can see a mirror finished case ....
http://timeless-av.co.uk/refurbishment/
bramble
Posts 397
bramble replied on Tue, Feb 18 2020 7:04 PM
Professional car sprayer would be best finish and best choice of colours.
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Bzguy
Posts 18
Bzguy replied on Fri, Feb 28 2020 1:54 PM
I changed the topic title, since I decided to refurbish the beaten up Beolab 2 that I recently picked up.
I hesitated between painitng (spray paint) or sand it down and see what it gives, so I started sanding : 80 grit, 120, 240, 400, 500, 600, 800, 1200, 1500, 2000. As from 500 grit I wet sanded.
After 2000 grit I used metal polishing cream, then 2 stages of Monello compound (car polish) with different pads.
You can still see some "battle scars" from its past, but I think it will look nice next to my Beolab 8000's (they need new covers, soon ... )
bramble
Posts 397
bramble replied on Fri, Feb 28 2020 3:13 PM
Wow....a lot of hard work, but looks awesome
leosgonewild
Helsinki, Finland
Posts 2,373
Nice job Big Smile
How many hours did it take you?
Bzguy
Posts 18
Bzguy replied on Fri, Feb 28 2020 4:36 PM
Thank you :)
It took me a good 20 hours of sanding, by hand. The hardest part is the 80 grit, the finer the grit, the easier it goes, and wet sanding is pretty satisfying, as you can see some shine coming through.
For the last steps (polishing compounds) I used a polishing machine and different pads (hard/soft)
matador43
Posts 1,373
matador43 replied on Fri, Feb 28 2020 4:47 PM
Beautiful.
Did you manage to keep the Band Olufsen marking on the top or did it disappear with the sanding?
Bzguy
Posts 18
Bzguy replied on Fri, Feb 28 2020 5:00 PM
Thank you
I tried to keep them, but it was too difficult, so they went away. The idea is to put small printed "Bang & Olufsen"  letters on it, I need to look where I can find someone who can.
Atarimaniac
Sweden
Posts 2
What about oxidisation? I thought non-anodized aluminium was highly prone to oxidisation?
Page 1 of 1 (13 items) | RSS
