Hi,does anybody know if it's possible to "simply" copy B&O Chips or did anybody actually try it?Example: Beolab 3500 SW 3.3 chip as a source to make a few more SW 3.3. chips for older Beolab 3500 with older Software. That would be good solution to keep parts even if supply from B&O isn't available anymore for old(er) devices.
Depends on the storage chip type;EPROMs (Beomaster 5500 etc.) can be copied,Mask-programmed CPUs (Beomaster 6000 etc.) can't.
Thank you.so key is to identify the chip types.
