B&O App and Deezer via Moment
This post has 7 Replies | 0 Followers
kimhav
Malmo, Sweden
Posts 314
kimhav Posted: Mon, Jul 6 2020 3:51 PM
Might be a while ago I did use the B&O App but noticed that I can't init Deezer from App anyomore to start Deezer play via the Moment; when was this changed?
Fansastic
The Hague, The Netherlands
Posts 768
kimhav:
Are you sure you are logged in to your Deezer account on the Moment? Will double check it but I’m able to play Deezer on my Moment on the B&O app. You must first select the Moment as active product in the app and then select music and play from your Deezer account.
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Mon, Jul 6 2020 3:56 PM
No issue with my Moment to start Deezer from the B&O App
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Mon, Jul 6 2020 4:05 PM
Yes, logged in as I'm currently playing from Deezer and only time I'm able to interact with Deezer is what is in the playlist when checking the App. But, I can't call Deezer from the app and I also remember that I previously had to login also to Deezer via the App which I can't find or locate if it's been shuffled around Big Smile
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Mon, Jul 6 2020 4:10 PM
kimhav:
In the App go in settings (profile icon), Music and Deezer
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Mon, Jul 6 2020 6:31 PM
Super - Found it! Totally missed out that it was under the profile icon; but sometimes ones is looking to hard that one doesn't see the obvious things Big Smile
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Mon, Jul 6 2020 6:39 PM
kimhav:
This demonstrates that the profile icon is not a good choice compared to the previous cogwheel, imho.
kimhav
Malmo, Sweden
Posts 314
kimhav replied on Mon, Jul 6 2020 7:45 PM
Lol! So something did change then since I was as you say looking for cogwheel or something more of inviting to configure something and clicking on the Moment to find something there....
Page 1 of 1 (8 items) | RSS
