Might be a while ago I did use the B&O App but noticed that I can't init Deezer from App anyomore to start Deezer play via the Moment; when was this changed?
kimhav:Might be a while ago I did use the B&O App but noticed that I can't init Deezer from App anyomore to start Deezer play via the Moment; when was this changed?
Yes, logged in as I'm currently playing from Deezer and only time I'm able to interact with Deezer is what is in the playlist when checking the App. But, I can't call Deezer from the app and I also remember that I previously had to login also to Deezer via the App which I can't find or locate if it's been shuffled around
kimhav:Yes, logged in as I'm currently playing from Deezer and only time I'm able to interact with Deezer is what is in the playlist when checking the App. But, I can't call Deezer from the app and I also remember that I previously had to login also to Deezer via the App which I can't find or locate if it's been shuffled around
Super - Found it! Totally missed out that it was under the profile icon; but sometimes ones is looking to hard that one doesn't see the obvious things
kimhav:Super - Found it! Totally missed out that it was under the profile icon; but sometimes ones is looking to hard that one doesn't see the obvious things
Lol! So something did change then since I was as you say looking for cogwheel or something more of inviting to configure something and clicking on the Moment to find something there....
