One is supposed to to be able to tell the difference? in behaviour though im finding so.
BL20 late version connected to avant 55
When in Wisa, if one has an option (as i do) for TV speakers only, the beolabs still illuminate, although they are muted ( but can here a slight hiss from tweeters)
Also if using Netradio or any device needing the internet, its seems that sometimes it says internet disconnect when it isnt.
When wired they behave as they should, ie not switching at all when calling for TV speakers only.
355f:One is supposed to to be able to tell the difference? in behaviour though im finding so. BL20 late version connected to avant 55 When in Wisa, if one has an option (as i do) for TV speakers only, the beolabs still illuminate, although they are muted ( but can here a slight hiss from tweeters) Also if using Netradio or any device needing the internet, its seems that sometimes it says internet disconnect when it isnt. When wired they behave as they should, ie not switching at all when calling for TV speakers only.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Correct, WISA speakers always turn on when the source is switched on even if not in use (e.g. not part of the current speaker group).
