Hello there
I have a question about a PC but not with Bang and Olufsen.
My Laptop is my work laptop and its a dell connected to a dell docking station via USB C cable for all connectivity.
Now my partner has a MSI laptop and it does not support Video over USBC or charging, charging I dont mind but when swapping laptops from the home setup we have to disconnect HDMI and USBC to swap over laptops.
I know this is really trivial BUT is there a way of combining the HDMI and USBC of the laptop together in a little hub like device so then i can just plug the docking station USBC cable into for his machine?
Eclipse 65V1-32Beosound M5Essence MK2BLI
Ah just saw this
I had a similar issue and had to buy a dock to run two monitors and my working remotely setup.
Work laptop is a ThinkPad and I went for the Lenovo Hybrid dock. It's a good dock actually. Although it doesn't dock by the traditional means of snapping in, it docks by the USB-C.
The specs at work said that the Hybrid dock doesn't charge my laptop T470S, however it does, which i'm happy with.
Good luck with the set up for both of you.
Aussie Michael:Ah just saw this I had a similar issue and had to buy a dock to run two monitors and my working remotely setup. Work laptop is a ThinkPad and I went for the Lenovo Hybrid dock. It's a good dock actually. Although it doesn't dock by the traditional means of snapping in, it docks by the USB-C. The specs at work said that the Hybrid dock doesn't charge my laptop T470S, however it does, which i'm happy with. Good luck with the set up for both of you.
