Hello to all,
I am thinking about getting a beosystem 4 second hand and in order to play 4k material on my projector use an Atlona upscaler more specifically the AT-HDVS-SC-RX
Has anyone used such a setup before?
I didn't get why do you need an upscaler. Can't you just connect the audio signal to the BS4 via coax spdif?
leosgonewild:I have a BS4 I dint use if you are interested.
Dante: I didn't get why do you need an upscaler. Can't you just connect the audio signal to the BS4 via coax spdif?
If I do so I will not be able to use the home control screen...
With my BeoSystem 4 I use a UHD player with dual HDMI outputs and an Apple TV with an HDFury HDMI splitter. You don't need the menu overlay at all for the Apple TV. For the UDH player, you really just need to remember how to access the disc menu and the main menu.
