Beosystem 4 and 4k material
This post has 6 Replies | 0 Followers
Tassos
Athens
Posts 323
Tassos Posted: Fri, Sep 25 2020 7:18 AM
Hello to all,
I am thinking about getting a beosystem 4 second hand and in order to play 4k material on my projector use an Atlona upscaler more specifically the AT-HDVS-SC-RX
Has anyone used such a setup before?
leosgonewild
Helsinki, Finland
Posts 2,373
I have a BS4 I dint use if you are interested.
Dante
Sao Paulo - Brazil
Posts 163
Dante replied on Fri, Sep 25 2020 11:08 PM
I didn't get why do you need an upscaler. Can't you just connect the audio signal to the BS4 via coax spdif?
jowus
Posts 161
jowus replied on Fri, Sep 25 2020 11:47 PM
leosgonewild:
How much do you want for the System 4!
Tassos
Athens
Posts 323
Tassos replied on Sat, Sep 26 2020 8:37 AM
Dante:
If I do so I will not be able to use the home control screen...
beojeff
USA
Posts 2,012
beojeff replied on Sat, Sep 26 2020 12:12 PM
With my BeoSystem 4 I use a UHD player with dual HDMI outputs and an Apple TV with an HDFury HDMI splitter. You don't need the menu overlay at all for the Apple TV. For the UDH player, you really just need to remember how to access the disc menu and the main menu.
Tassos
Athens
Posts 323
Tassos replied on Mon, Sep 28 2020 8:21 AM
Hello Jeff,
I really need the home control screen to be available for both tv and beamer cause I am using the BLI to control my door. My setup consists of a V1 an epson projector and an atlona 5x2 switch. All stbs are on the atlona and the spdif of the atlona goes to the spdif of V1. In simple words I am using the v1 to process audio and I choose which screen I want to use (v1 or beamer).
Beosystem 4 would be the ideal solution for me but it is not 4k and as far as I understand b&o are not interested in producing at least a beosound stage with proper surround capabilities!!!!!Sad
Page 1 of 1 (7 items) | RSS
