Hi everyone,
I bought a Stage online which got delivered today and I tried to set it up. After setting it up in the Google Home app it said that it had to be updated. After that it was "restarting" for a long time, nothing happened. I finally unplugged the Stage after about an hour.
Now all I get is flashing red light, the Stage cannot be found in the B&O app and the Google home app says the product is "outdated or needs to be reset". I tried pressing the settings button on the Stage to do a factory reset, but it's not working. The two lights simply keep pulsing red.
I have no idea what I can do? Is there any other way to reset the Stage?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
