Stage flashing red lights - not starting
This post has 1 Reply | 0 Followers
freezer
Posts 1
freezer Posted: Fri, Nov 20 2020 10:03 PM
Hi everyone,
I bought a Stage online which got delivered today and I tried to set it up. After setting it up in the Google Home app it said that it had to be updated. After that it was "restarting" for a long time, nothing happened. I finally unplugged the Stage after about an hour.
Now all I get is flashing red light, the Stage cannot be found in the B&O app and the Google home app says the product is "outdated or needs to be reset". I tried pressing the settings button on the Stage to do a factory reset, but it's not working. The two lights simply keep pulsing red.
I have no idea what I can do? Is there any other way to reset the Stage?
Hiort
Sweden
Posts 2,895
Hiort replied on Sat, Nov 21 2020 5:06 PM
Flashing red lights indicate problem with WiFi connection.
https://support.bang-olufsen.com/hc/en-us/articles/360039932931-What-do-the-light-indicator-colours-on-my-Beosound-Stage-mean-
Page 1 of 1 (2 items) | RSS
DigiCert Secured Site Seal
