A young bloke in his early 20's with an expensive hobby..
Present:
Beovision 4-50 Full HD, Beosystem 3, DVD2, Beolab 8000 MK2, Beolab 7-2, Beotime alarmclock, Beosystem 2300, Beolab 2500, Beovision 8-40, Beosound 8, Beo5, Beo4 DTV
Sold:
BeoMaster 7000, BeoVox RL7000, BeoCenter 6-23 DVI, Beolab 4, B&O F1000 furniture, Beovision 8-26
Is the SCART cable fully wired? Some of the cheaper ones are not, yet the B&O data requires extra pins to be connected to pass data to/from the DVD2. Your symptom would suggest this as the cause.
See here: https://www.beoworld.org/beotech/mclconn5.htm
Pin 8 = data
8000Kristian:Thanks for the quick response Guy. I don't know if the cable is fully wired, but I can see all 21-pins in the plug. Do you suggest that the DVD2 wouldn't get IR-signals through HDMI? So the only possible connection is a fully wired SCART-cable?
Often SCART cables have all the pins without them all being connected - best to check with a multimeter.
And yes, I understand that the DVD2 must get IR signals via the SCART and not the hdmi. Old technology I know but it should work!
Further to my last, one thing that I didn't realise with the DVD2 is that there are 6 recessed buttons on the back (under the hdmi socket) that enable you to control the player. So at least you can test if it works!
From the service manual (available if you upgrade to silver) they are:
S1 Open / Close
S2 Next
S3 Standby
S4 Record
S5 Stop
S6 Play
And a search of the old forum gives this useful answer: https://archivedarchivedforum2.beoworld.org/forums/t/35740.aspx
8000Kristian:Thank you so much Guy . When i get home from work, i will try to test out the 6 buttons on the back as you suggested, and then I can buy a new SCART-cable afterwards. Happy that the unit was cheap, when I have to use SCART .
No problem - happy to help! And my only TVs are BV6s hence SCART is being used widely here!
Were you able to get this to work, and if so, how?
Sigh - that would work if my Beosystem 3 had a SCART connector. Apparently the version available in the US doesn't have one.
MikeGriese:Sigh - that would work if my Beosystem 3 had a SCART connector. Apparently the version available in the US doesn't have one.
I am working with B&O Support on a solution, but they have been a bit frustrating for some reason.
I once considered getting a DVD2 and trying a solution of connecting a SCART breadboard to make a connection of the PUC cable to the appropriate SCART pin.
As an afterthought to my last post: I suspect that B&O would have to create a PUC to make use of the PUC cable socket for a DVD2.
Looks like my request has been bumped up to engineering. Hopefully they will have a solution.
Hmmm... now support is referring me to a retailer.
MikeGriese: Hmmm... now support is referring me to a retailer.
Sounds like typical BeoCare arrogance.
Steve at Sounds Heavenly might be able to create a cable to get the PUC signal from mini-RCA to SCART using the correct pin. However, you would also need a custom PUC entry made to load unto your BeoSystem 3.
I'll give him a go.
Finally heard back from a retailer. The recommended approach is to hack a SCART cable to connect the CTRL port of the Beosystem 3 to pin 8 of the SCART port on the DVD 2. Parts are on the way.
Ok - finally got everything working between the DVD 2 and the US spec Beosystem 3. The process I used was to use a male SCART connector and mate it with essentially a 3 lead IR Eye cable. The IR cable plugs into the CTRL socket of an AV channel on the Beosystem 3. Audio and video signals are by HDMI. I picked up ground from the SCART ground shell and attached the signal lead from the cable to pin 8 of the SCART connector. All is good.
MikeGriese: Ok - finally got everything working between the DVD 2 and the US spec Beosystem 3. The process I used was to use a male SCART connector and mate it with essentially a 3 lead IR Eye cable. The IR cable plugs into the CTRL socket of an AV channel on the Beosystem 3. Audio and video signals are by HDMI. I picked up ground from the SCART ground shell and attached the signal lead from the cable to pin 8 of the SCART connector. All is good.
Reviving this old post, are you able to clarify more regarding how you made your cable. Which pin on the plug connected to pin8 and where did the other wires go?
Thanks in advance
Stoobie
