Beovision 10-40 MK3 and Beolab 3500
This post has 1 Reply | 0 Followers
SirPump
Posts 14
SirPump Posted: Tue, May 9 2017 9:45 AM
I'm trying to connect my Beolab 3500 link speaker to the Beovision 10-40.
It is working almost fine, for instance the analgoue TV, DTV and Apple TV is sounding throught the BL3500 and i can control the sources throug the puc cables connected to the BV10-40.
The only problem i have is that when i want to listion to the audio of the DTV source i need to switch on the BV10-40 first, then go to he link room where the BL3500 is and then press DTV there as well.
If i select DTV on the BL3500 directly i can see that my BV10-40 switches on, the green light is showing, i see on the DTV source (Horizon BOX) that it switches on as well, however no sound is given through the BL3500.
Does anyone know what to do here?
JamesSamuel
Netherlands
Posts 51
I have the same problem.
Did you figure this out?
Page 1 of 1 (2 items) | RSS
