I'm trying to connect my Beolab 3500 link speaker to the Beovision 10-40.
It is working almost fine, for instance the analgoue TV, DTV and Apple TV is sounding throught the BL3500 and i can control the sources throug the puc cables connected to the BV10-40.
The only problem i have is that when i want to listion to the audio of the DTV source i need to switch on the BV10-40 first, then go to he link room where the BL3500 is and then press DTV there as well.
If i select DTV on the BL3500 directly i can see that my BV10-40 switches on, the green light is showing, i see on the DTV source (Horizon BOX) that it switches on as well, however no sound is given through the BL3500.
Does anyone know what to do here?
I have the same problem.
Did you figure this out?
