I purchased my BeoMaster 5 and BeoSound 5 a while back from a third party. I connected everything and it appears to be working fine. I would like to erase all of the previous owner's music from my Beomaster 5. Is there some type of reset button? How to I wipe the slate clean?
Why would you want to erase them? Cant add on your collection and combine together?
It is just a harddrive!
Locate this (as a networked drive) on your network and delete the music files.
And - when you are at it - copy your own files to it.
Basicly you are right - you are not allowed to use ‘someone elses’ files..........but, maybe you just don’t like the music on the drive ;-)
I just felt that it's not right using someone else's music/files.... However, This leads me to another question. I connected a CAT5 cable from the BeoMaster (the network CAT5 plug on the back of my BeoMaster 5) to my WiFi modem. My computer sees the BeoMaster5 drive, but when I click on it, nothing happens. Is there some type of connection process I need to perform? I'm a novice and inexperienced with computers.
