Problem with the last update for Transmitter 1
TJCarroll
Posts 2
TJCarroll Posted: Fri, Apr 30 2021 12:49 PM
After updating my Transmitter 1 I am not able to access my system. I have a Transmitter 1 connected to a Beosystem 4, with Beolab 17, 18, 19's attached. Previously this was an ideal setup for my situation. However, since updating there is no way of accessing the system. The transmitter has a continually flashing light. Would be grateful for any advice.
All the best, Trevor
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Fri, Apr 30 2021 12:51 PM
Did you go through the pairing process after the update ?
TJCarroll
Posts 2
Yes, but the transmitter won't talk to the Beosystem 4. The speakers go through the connection process when powered on, but when they get to green they continue flashing. The ethernet connection to the Besystem 4 (not sure  what the component is called) continues to flash red.
Jack
Poland
Posts 30
Maybe it will help ..
USB
https://bangolufsenassistentgohe.blob.core.windows.net/manuals/APPS_AND_ACCESSORIES/BEOLAB_TRANSMITTER_1/wpl-update-15-01-18.zip
mbolo01
Louannec - France
Posts 2,035
mbolo01 replied on Sat, May 1 2021 4:15 PM
TJCarroll:
According to the doc:
– Green (flashing): A software update is in progress, during which the speaker cannot play. Do not disconnect from the mains.
Green (flashing quickly): If you have a wireless transmitter in your setup, the speaker is in associate mode and ready to be connected to the wireless transmitter.
I guess you have not gone through the full pairing process after the software update, or something wen wrong and you have to go through it again.
Page 1 of 1 (5 items) | RSS
