After updating my Transmitter 1 I am not able to access my system. I have a Transmitter 1 connected to a Beosystem 4, with Beolab 17, 18, 19's attached. Previously this was an ideal setup for my situation. However, since updating there is no way of accessing the system. The transmitter has a continually flashing light. Would be grateful for any advice.
All the best, Trevor
Yes, but the transmitter won't talk to the Beosystem 4. The speakers go through the connection process when powered on, but when they get to green they continue flashing. The ethernet connection to the Besystem 4 (not sure what the component is called) continues to flash red.
Maybe it will help ..
USB
https://bangolufsenassistentgohe.blob.core.windows.net/manuals/APPS_AND_ACCESSORIES/BEOLAB_TRANSMITTER_1/wpl-update-15-01-18.zip
TJCarroll: The speakers go through the connection process when powered on, but when they get to green they continue flashing.
According to the doc:
– Green (flashing): A software update is in progress, during which the speaker cannot play. Do not disconnect from the mains.
– Green (flashing quickly): If you have a wireless transmitter in your setup, the speaker is in associate mode and ready to be connected to the wireless transmitter.
