Sometimes you have to tick certain entries as "shown" in order to have access to more products. For example, did you try ticking DTV as "shown" to see if it then makes DTV2 available?
beojeff:Sometimes you have to tick certain entries as "shown" in order to have access to more products. For example, did you try ticking DTV as "shown" to see if it then makes DTV2 available?
Eclipse 65V1-32Beosound M5Essence MK2BLI
Razlaw:The missing sources, such as DTV2, are not available to be ticked.
Carolpa:
I rest my case
Could it be these sources were previously assigned another name? Do you have any strangely named sources?
Razlaw: beojeff: Sometimes you have to tick certain entries as "shown" in order to have access to more products. For example, did you try ticking DTV as "shown" to see if it then makes DTV2 available? The missing sources, such as DTV2, are not available to be ticked. They are missing from the list that sources to be shown/available are selected/ticked from.
I'm not sure that you understood my post. For example, you won't see Matrix 5 at all unless you first tick Matrix 4 to be shown as a source.
beojeff:I'm not sure that you understood my post. For example, you won't see Matrix 5 at all unless you first tick Matrix 4 to be shown as a source.
Razlaw: beojeff: I'm not sure that you understood my post. For example, you won't see Matrix 5 at all unless you first tick Matrix 4 to be shown as a source. Yes I did misunderstand. And yes, that was the problem. Thank you!
Great! There are a lot of hidden sources like that -- especially in the LIGHT and CONTROL lists. Once you reveal the hidden sources and tick them as "shown", you can go back and hide what you don't want.
Carolpa: I rest my case
So set the BR1 as Beo4 (even the Bluetooth ones) ...et voila.... all the ML sources are available.
beojeff:Great! There are a lot of hidden sources like that -- especially in the LIGHT and CONTROL lists. Once you reveal the hidden sources and tick them as "shown", you can go back and hide what you don't want.
