BR1 missing products
This post has 16 Replies | 1 Follower
Razlaw
Posts 4,345
Razlaw Posted: Mon, Jul 5 2021 6:45 PM
Have been doing some programming of my BR1s. After getting one set up the way I wanted I went to the second one and noticed multiple products missing. In particular, DTV 2 is not present on it. Any suggestion about why products are missing? Or any way to get them all to show again, short of trying a full factory reboot/reset? When I look at the Version menu it says “Font Invalid”.
Thanks!
beojeff
USA
Posts 2,012
beojeff replied on Tue, Jul 6 2021 11:46 AM
Sometimes you have to tick certain entries as "shown" in order to have access to more products. For example, did you try ticking DTV as "shown" to see if it then makes DTV2 available?
Razlaw
Posts 4,345
Razlaw replied on Tue, Jul 6 2021 12:50 PM
beojeff:
The missing sources, such as DTV2, are not available to be ticked. They are missing from the list that sources to be shown/available are selected/ticked from.
Seanie_230
UK
Posts 2,278
Hello is the remote Bluetooth?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Jul 6 2021 6:09 PM
Razlaw:
Razlaw
Posts 4,345
Razlaw replied on Tue, Jul 6 2021 6:20 PM
Carolpa:
DTV 2 and some others are not present on the one remote. They are on my other BR1 and fully able to be checked to display as a source or not.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Jul 6 2021 6:31 PM
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Jul 6 2021 6:38 PM
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Tue, Jul 6 2021 6:45 PM
I rest my case
1990
Posts 521
1990 replied on Tue, Jul 6 2021 7:01 PM
Could it be these sources were previously assigned another name? Do you have any strangely named sources?
Seanie_230
UK
Posts 2,278
If you have it On the Bluetooth one it will be getting the list from the TV itself.
If one is IR it’s manually configured perhaps.
Also if both are Bluetooth perhaps one is looking at a different product, are both paired with your TV ?
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
beojeff
USA
Posts 2,012
beojeff replied on Tue, Jul 6 2021 7:38 PM
Razlaw:
beojeff:
I'm not sure that you understood my post. For example, you won't see Matrix 5 at all unless you first tick Matrix 4 to be shown as a source.
Razlaw
Posts 4,345
Razlaw replied on Tue, Jul 6 2021 8:02 PM
beojeff:
Yes I did misunderstand. And yes, that was the problem. Thank you!
beojeff
USA
Posts 2,012
beojeff replied on Wed, Jul 7 2021 12:52 AM
Razlaw:
beojeff:
Great! There are a lot of hidden sources like that -- especially in the LIGHT and CONTROL lists. Once you reveal the hidden sources and tick them as "shown", you can go back and hide what you don't want.
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Wed, Jul 7 2021 5:57 AM
Carolpa:
I rest my case
don't think to difficult...........these sources are Beo4 sources, right!
So set the BR1 as Beo4 (even the Bluetooth ones) ...et voila.... all the ML sources are available.
Razlaw
Posts 4,345
Razlaw replied on Wed, Jul 7 2021 1:20 PM
beojeff:
Thanks again!
Razlaw
Posts 4,345
Razlaw replied on Fri, Jul 9 2021 3:11 AM
Edit delted
Page 1 of 1 (17 items) | RSS
