Hello all,
I just got a pair of S45-2's for 60$. Unfortunately, one of the speakers needs a new woofer and midrange. Anyone have any recommendations on replacement drivers. Im trying to keep the repair under 50$ or so.
Thanks, Noah
-Noah M.
RL 60.2, Beogram 5500, Beomaster 5500, Master Control Pannel 5500, Audio Terminal Remote, H9i, Beovox s45.2, Beosystem 2500 , Beogram 1602, Beolink 1000 remote, Beosound 2000, Beoremote 4.
Looking for: Beocenter 8000
The woofer most likely suffers from a shifted magnet, locking the voicecoil and cone.This is often repairable. Do a search in the forum and you'll find more information.The same can actually have happened to the midrange.
If this fails ask at Beoparts or PM me.
Forget replacing with modern drivers. You will not find anything matching the custom specs of that woofer (regardless of the price).
I don't believe its a shifted magnet. I will PM you.
What is the problem exactly?
